larkim
Established member
I am a small bit of a newbie and not really used to getting under the bonnet so to speak, but I need to replace my pads on the 1.1 Eco Active panda 2010.
I should say, I have done this before - once - on this car with no mishaps or issues, and I am generally reasonably competent and methodical, so rest assured that any advice you give will not make you liable for some idiot haring down the motorway without working brakes.
So, tonight I am swapping out my old brake pads and replacing with new. They are very worn, and I simply don't have the time or the convenient option to take to a garage.
The last time I did it I remember unscrewing the cap on the brake fluid reservoir to allow the fluid to push back when I slowly wind the calipers back in. Is that actually necessary, or is that just a precautionary step? I am aware of the effect of brake fluid on paintwork and its hydroscopic nature.
The second question is around support. Last time I think I relied on a mechanical jack with the removed tyre placed underneath the car to avoid a catastrophic fall to the ground. Since then I've been passed some axel stands, and would therefore intend to use them. However, I'd need some guidance as to where to place them under the car to avoid damage.
A photo would be most helpful, or a diagram. Sadly just saying "directly onto the subframe" will mean little to me as my experience under there is so limited.
Thanks in advance for the help!
