Old 08-10-2019   #1
100HP Rear brakes.
Hi, I've just fitted new discs and pads to the rear of the Panda 100HP. Drivers side rear all worked fine but.....passenger side (Near side Left side ?) once reassembled I had no brakes? After a bit of pedal pushing I've now got a foot brake but still no hand brake. Do anyone have any helpful suggestions?
I used a windback tool on both sides turning clockwise although some say anti clockwise for passenger side?
Cheers,
Andy
AndyS65 is offline Reply With Quote Quote
Old 08-10-2019   #2
Re: 100HP Rear brakes.
Check the pads have fully extended and the hand brake cables might need adjusting. You have to remove the centre "console" to get at them.
The best way to test rear hand brakes is to reverse the car with the brakes on. The wheel that does not skid needs the cable to be tighter. You can try it with the foot brakes but the more powerful fronts may prevent progress.
DaveMcT is offline Reply With Quote Quote
Old 08-10-2019   #3
Netherlands
Did you make sure that the notch on the caliper was in the right position?
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Old 08-10-2019   #4
No I didn't line any notches up. Please explain.
Thanks.
Old 09-10-2019   #5
Netherlands
The callipers have 4 dents in them. One of them has to line up with the pin on the pad.
gr J
Old 09-10-2019   #6
As above, check the position of the notch on the caliper piston is correct. You need to actuate the handbrake multiple times after winding the pistons back to reset their positions with the new disks/pads.
dac69er is offline Reply With Quote Quote
Old 10-10-2019   #7
Thanks All. One pad had a dimple for the piston to locate on the other pad didn't. I obviously got it wrong way round. So now swapped round and positioned to line up with one of the four cut aways in the piston I have a hand brake that works but the foot brake is poor. After a short drive 3 disks are hot but NSR is cold? If I jack the car up and apply the hand brake I can't rotate the wheel, but if my wife pushes the foot brake I can with some effort still rotate the wheel. The wheel spins freely when all brakes are off. Looking at the piston it pushes out maybe 5mm when the foot brake is operated but retracts by the same amount when it is released? Has anyone seen this before.
Thanks,
Andy
Old 11-10-2019   #8
Disc brake pads touch the disc with brakes off so only have to move a tiny amount to apply the brakes. If the sliding pins or the piston are sticking the brake will not work. Worst case you need a new or reconditioned caliper.
Thanks AndyS65 thanked for this post
Old 11-10-2019   #9
Thanks. Handbrake works well, the slides are free and the piston moves out when you apply the foot brake but when you release the foot brake it moves back again. I may try bleeding the brake, not for any logical reason but it is something I have not tried.
Old 11-10-2019   #10
If it ends up being the caliper has anyone bought one recently and have a recommend supplier?
Quote Originally Posted by DaveMcT View Post
Old 11-10-2019   #11
Netherlands
Fresh brakefluid and properly bled?
gr J
Old 11-10-2019   #12
Yes, I've no idea how old the brake fluid is and to be honest it does look a bit cloudy.
Old 11-10-2019   #13
New brake fluid will not fix a jammed brake piston.
Contact these people they may have what you need
https://www.ebay.co.uk/itm/FIAT-GRAN...QAAOSwVzRbaXUC
Also call Shop 4 parts (phone not website)
https://www.bcs-automotive.co.uk/bra...refurbishment/
Old 12-10-2019   #14
Thanks Dave, you are of course correct. I don't think the piston is jammed though because with the caliper removed I've seen the piston extend by about 5mm when the pedal is pushed, however it retracts by 5mm when the pedal is released. Unless it's tight in the seal and stretching it then it's pulling it back l may get an unwilling volunteer to pump the pedal whilst I try a bit lube on the piston whilst it goes out and in.
Thanks again for aĺl suggestions.
Old 12-10-2019   #15
Netherlands
Fresh fluid is always the first thing I do to a new (to me) car. Currently on ATE racing. Old fluid has attracted lots of water, lowering boiling point, causing rust and sometimes internal desintegrating brakehoses.
gr J
(T) Change rear drum brakes by disc brakes anyzunstudios Grande Punto 12 25-02-2017 12:47
(T) 100hp - squeaky squeak rear brakes AB100 Panda 5 12-01-2014 17:25
(Tu) 100HP Brakes lacey_punto Panda 14 25-01-2013 21:40
(G) 100hp rear brakes/handbrake adjustment nokesy Panda 0 28-09-2011 21:59
(G) 100HP brakes simer Panda 8 09-02-2007 20:20
