Technical 100HP Rear brakes.
AndyS65
Hi, I've just fitted new discs and pads to the rear of the Panda 100HP. Drivers side rear all worked fine but.....passenger side (Near side Left side ?) once reassembled I had no brakes? After a bit of pedal pushing I've now got a foot brake but still no hand brake. Do anyone have any helpful suggestions?
I used a windback tool on both sides turning clockwise although some say anti clockwise for passenger side?
Cheers,
Andy
Check the pads have fully extended and the hand brake cables might need adjusting. You have to remove the centre "console" to get at them.
The best way to test rear hand brakes is to reverse the car with the brakes on. The wheel that does not skid needs the cable to be tighter. You can try it with the foot brakes but the more powerful fronts may prevent progress.
No I didn't line any notches up. Please explain.
Thanks.
As above, check the position of the notch on the caliper piston is correct. You need to actuate the handbrake multiple times after winding the pistons back to reset their positions with the new disks/pads.
Thanks All. One pad had a dimple for the piston to locate on the other pad didn't. I obviously got it wrong way round. So now swapped round and positioned to line up with one of the four cut aways in the piston I have a hand brake that works but the foot brake is poor. After a short drive 3 disks are hot but NSR is cold? If I jack the car up and apply the hand brake I can't rotate the wheel, but if my wife pushes the foot brake I can with some effort still rotate the wheel. The wheel spins freely when all brakes are off. Looking at the piston it pushes out maybe 5mm when the foot brake is operated but retracts by the same amount when it is released? Has anyone seen this before.
Thanks,
Andy
Disc brake pads touch the disc with brakes off so only have to move a tiny amount to apply the brakes. If the sliding pins or the piston are sticking the brake will not work. Worst case you need a new or reconditioned caliper.
Thanks. Handbrake works well, the slides are free and the piston moves out when you apply the foot brake but when you release the foot brake it moves back again. I may try bleeding the brake, not for any logical reason but it is something I have not tried.
If it ends up being the caliper has anyone bought one recently and have a recommend supplier?
Yes, I've no idea how old the brake fluid is and to be honest it does look a bit cloudy.
Thanks Dave, you are of course correct. I don't think the piston is jammed though because with the caliper removed I've seen the piston extend by about 5mm when the pedal is pushed, however it retracts by 5mm when the pedal is released. Unless it's tight in the seal and stretching it then it's pulling it back l may get an unwilling volunteer to pump the pedal whilst I try a bit lube on the piston whilst it goes out and in.
Thanks again for aĺl suggestions.
New brake fluid will not fix a jammed brake piston.
Contact these people they may have what you need
https://www.ebay.co.uk/itm/FIAT-GRA...366810&hash=item3602ca5d1a:g:luQAAOSwVzRbaXUC
Also call Shop 4 parts (phone not website)
https://www.bcs-automotive.co.uk/brake-caliper-refurbishment/
Old brake fluid is destructive stuff.
When I change brake pads I push back the piston(s) with bleed nipples open. That blows out the bad stuff and avoids the master reservoir overflowing. Top up as necessary. Flush the system fluid according to the service schedule.
Old brake hoses can delaminate internally creating a check valve effect which can cause brakes to bind. Braided hoses cannot do this but you cannot clamp them to avoid fluid loss. They need a suitable end plug.
