can any body tell me if they have trouble with the clutch fork, when pressing clutch pedal it makes a load noise, coming from clutch housing, there is no clutch slip, and drives well
When do you get the noise? Engine running, engine stopped, clutch down or clutch up?
Noise/rattle engine running in neutral that stops when pedal goes down indicates gearbox input shaft bearing.
Noise when pedal goes down indicates clutch release bearing. But it could also be the pressure plate spring such as a broken tine.
