- Sep 14, 2009
- 19,492
- 3,294
With engine cold make sure coolant level is above minimum. Use car until engine is hot and you'll see the level rises. This is normal.
If you set the level to full with the engine cold the excess coolant will be blown out of the system as it expands with temperature. The level will then be lower when the engine has cooled down.
Take the car to any good independent mechanic. They will do the professional tests - compression, hydrocarbons in coolant, UV stains and Mk1 eyeball.
There will be costs associated. If the car is found to be all good you pay those costs. If its not you get an estimate for repairs and talk to the seller.
