Normally, if there's a 'reverse mode' there'll be a pin which should be linked to the reverse switch. Looking at the picture you've linked nothing says reverse specifically, but I'd say it's either pin 9 or 13 is the culprit. Check and see if the standard plug has a wire going to either of these pins.
