The problem I have is a tricky one . When the engine starts initially (cool), it idles fine and will slot into 1st and reverse fine , the rev counter is steady at 850 -900, as it warms up a matter of 3mns say the rev counter will jerk up and down from 900 to 1050 .You try a gear and it immediately cuts out. I f you let it idle as well without doing anything it will cut out.
If you try and keep the revs high , say 1200 and slot a gear it will also cut out , giving the impression a reasonable amount of drag from the clutch . This could be normal as the speed indicator will think that were off and running.
My theory is that the speed sensor/transmitter on the back of the gearbox is telling lies to the engine ecu, I had it tested at the local Fiat garage and they said it was ok. (not convinced).
Of course it could be faulty wiring , but again nothing showing except the diag says there is an intermittant fault in a Can line to a Microprocessor 2 , what ever that is . I'm about to clear all these faults as I have been trying different things to eliminate things.
Overall no real evidence of decent fault codes .
Is there another speed sensor feeding the rev counter or is the gearbox one the only one.
I am talking selespeed on a 07 plate Panda 1.2 8v.
