Thread Tools
Old 16-06-2019   #1
Smile yellow dashboard symbol
hi, on driving my 55 plate multijet,on friday afternoon, a steady yellow( non flashing) symbol came up on the dashboard. it looks like half a car with a padlock. my m8 says its a immobiliser fault maybe linked to ignition key. i pulled over & switched the ignition off then back on. it has not reappeared and i have used the panda a few times since. anything to worry about, guys? cheers, steve
steve w hebburn is offline Reply With Quote Quote
Old 16-06-2019   #2
varesecrazy has donated!
Re: yellow dashboard symbol
Read the fault codes..
It may well be a momentary loss of chip signal.
But the code should tell the tale
Old 17-06-2019   #3
It's telling you that the car does not completely recognise the signals from your key.
Often, this is a one-time hiccup, and as you said, it may not show up again. If the car starts normally then you can ignore it, but it is a wake up call to check over the car's basic electrics - battery condition, fuses etc.
Sweetsixteen is offline Reply With Quote Quote
Old 17-06-2019   #4
Mine does it occasionally though I have no reason to suspect the electrical systems. The immobiliser antenna can be weak so changing that is worth doing.
DaveMcT is offline Reply With Quote Quote
Old 17-06-2019   #5
Trader Rating: 1
portland_bill has donated!
Try the spare key.
Make sure it is handy.
If you don't have a spare, getting one is now urgent.
Likes jrkitching liked this post
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 17-06-2019   #6
Moderator
Quote Originally Posted by DaveMcT View Post
Mine too.
Perhaps once every two years or so; the car still drives normally with the immobiliser light on, and it resets once the car restarts.
If it happens more often, then it's worth investigating further.
Likes steve w hebburn liked this post
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 17-06-2019   #7
hi, guys thanks for the replies. i only have the blue key, newish battery fitted. no faults codes on my maxiscan ms300. & where is the immobilliser antenna fitted ? cheers, steve
Old 17-06-2019   #8
Moderator
Mine uses the type 2 key system, so this is a common issue across both key types.
Interesting that when this happens, the immobiliser deactivates (the car does start), but the warning stays on.
Quote Originally Posted by steve w hebburn View Post
I would not want to own any modern car without having two fully working keys; if one fails and you have no backup, the recovery options may be both limited and costly.
The sensor for the transducer is, I believe, in a ring around the ignition switch. Some folks have disabled the immobiliser by removing the transducer from a working key and mounting it permanently next to the sensor.
Old 17-06-2019   #9
Happens occasionally to me as well, probably about 4 times over the last 90k miles, but turning the motor on and off again quickly sorts it.
Kronkron is offline Reply With Quote Quote
Old 17-06-2019   #10
The antenna is a black ring (under the plastic covers) around the ignition lock. But simply swapping it out might not solve the problem and they are not especially low cost.
You can get key chips cloned . A forum search will show members who do this.
Old 17-06-2019   #11
hi, guys thank you for the info. if i do break down my bro has a galaxy, and i have a straightbar. amber beacon, & a "on tow" magnetic numberplate. ha ha .hope i dont need them. regards, steve
Old 17-06-2019   #12
Netherlands
Mine does that when I wait too long to turn the key after putting it in the ignition. I think it's even mentioned in the manual.
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Old 17-06-2019   #13
Trader Rating: 1
The light can also illuminate if the key is turned too quickly. The car starts, but both computers have not had time to agree the immobiliser so the light is put on.
Correct starting procedure.
Turn key to ign. (all dash lights on)
Fuel pump will run to pressurise the system, glowplug light may illuminate briefly, longer on colder days.
As soon as glowplug light extinguishes, turn to start.
Even if in a hurry, don't jump in and turn the key directly to start, as this may cause the light to illuminate. On a cold day, it will also waste fuel as it is pushed through unburnt as it tries to fire in a cold combustion chamber, let the glowplugs do their stuff.
Get a spare key asap.
Likes steve w hebburn, jrkitching, Kronkron liked this post
Panda Alessi
Thread Tools
(G) Dashboard symbol blackJTD 500L 12 19-07-2015 21:51
(G) (!) symbol on dashboard Xbox Newcastle Punto (Mk2/2b) 26 01-07-2011 00:01
(T) Dashboard symbol?? LELA981 Cinquecento / Seicento 5 22-10-2008 11:03
(G) Dashboard Symbol - Yellow man Stanford Punto (Mk2/2b) 6 07-06-2008 00:57
(G) Dashboard Symbol DjStunt Punto (Mk2/2b) 11 23-11-2007 17:49
