Multiodd
Just wanting to clarify if the propeller shaft really does split in two, i've uploaded a picture of said joint and the remains of the centre bearing.
As many have found, new bearing supports are readily available (I've bought one to use here if possible).
Looking at the various sale sites, some show this uv joint with a bolt sitting within it and this must be undone to allow the joint to spilt. I am unsure if this is true on the panda mk2 however. (the photo could be generic)
My joint has no centre bolt, but it would be rather beneficial if it still did (and alot cheaper too, than a whole new propeller shaft). I am hoping just is just held in with locktight and a split pin, but so far it will not spilt.
If someone has done this (and process used) can advise I would be very grateful
