Hi All
I'm trying to find out why the mother-in-laws 2010 Fiat Panda 1.1 Active Eco is not producing hot air from the heater vents even when the engine temperature is up. On top of that there is a sloshing water sound coming from behind the dashboard, and it's not the usual issue of water being collected in the bulkhead caused by blocked drain plugs. Also, her engine seems to run a lot hotter than normal, hitting at least 3/4's on the temperature gauge. I've noticed there are quite a lot of posts on here relating to no hot air from the vents, but most, if not all I've seen, relate to Pandas with AC / Climate Control, the in laws Panda doesn't have either of these.
We suspected thermostat so we replaced that and also replaced the coolant in her car and ensured the system has been bled, but still no heat is coming from the vents, and the sloshing water noise is always there. I have noticed that the coolant level in the expansion tank can appear low one day, yet another day might be right up the neck of the expansion tank, to me that sounds like pressure is not being kept up with the cooling system. I've checked the oil and underneath the oil filler cap and there doesn't seem to be any signs of oil contamination, so I'm totally stumped.
Any ideas what might be going on, or other things to investigate would be greatly appreciated, the in law is starting to worry about driving the car now, and it would be nice to get her on the road again so she doesn't keep asking for lifts here and there!!!:bang:
