Wasgehabendas
- May 18, 2018
- 119
- 35
Hi guys,
I have a Fiat Panda 1.1 2006 with a clutch cable. Clutch pedal has become stiff for the past 10 000 km. Sometimes, but not often, it won't go into 1st or reverse and then if you want to put it in the first gear you have to go into reverse. Same goes for the reverse, you need to put it in the first gear then select reverse. Some say it is normal.
Gears are hard to select on cold starts. It needs some 10-15 driving and then it goes smoothly.
Is it normal for clutch to last only 85 000 km on this model? Most of the ride is throughout city.
Is clutch worn out? I am afraid that clutch cable may snap because of the hard clutch. What do you think?
