Interesting. My handbook specifies 75W-80 to API GL5
As you say, Interesting! Oil specs/applications never seem simple.Interesting. My handbook specifies 75W-80 to API GL5
Your tool kit doesn't have any ring/open ended spanners.
A good set is essential, so it's worth adding.
A socket works from above the nut or bolt, whereas a ring works at the same level as the bolt head. One will often do what the other can't.
A little odd. It must be the same gearbox? Maybe FIAT changed their minds between 2004-10!
After changing the oil, the transmission feels much smoother. It would crunch sometimes changing down to 3rd, but that's gone now. Maybe the oil level was low. One of the reasons I prefer to carry out my own service even with FSH.
My handbook just specifies checking the gearbox oil level every 80,000km, I don't know if there's a schedule for replacing it.
Mine's done 95k miles and I'd be surprised if it's been changed before. You could just top it up to the level of the filler plug.
But I've not had my car long, its service was due and I just like to know that fluids are good. Makes me feel happier, and maybe the car too
Yes, important to be done with the car flat and level as over or under filing both come with their own detrimental effects. My driveway slopes gently down towards the road so I reverse it onto the driveway, chock the rear wheels and jack the front up. - axle stands used - which then gives me good access. I use a spirit level on the sills and across the bonnet shut panel to get it as level as reasonably possible without getting too anal about it!I take it that gearbox oil change has to be done on flat surface without car jacked up?
That's a good idea! I would still prefer to make sure I can loosen the filler plug before the drain plug thoughYou will get less messy if you just undo the drain plug. Air in the box prevents the oil from flooding all over your arm. You can then remove the filler plug to help the last drops out.
Need to get some penetrating oils, because all I have is a couple of cans of WD40 in the shed.
I've tried a lot of releasing fluids over the years. WD40 seems to be the go to these days for many people but where it really excels is at dispersing moisture - the clue is in the WD - if you think it's good try some Plus Gas Formula A. I've never found anything better. GT85 also has a strong following. My American friend favours PB Blaster which seems to be available in a limited way now a days over here.
Just a few suggestions - hope it's helpful?
Jock
