when the weather get cold we get loads of cooling issues
heaters only blowing warm
P0115 error
radiator fans coming on fast.
gauge dropping down occationly.
gauge only going up 1/4 way
90% are down to a missing rubber gasket inside the thermostat. Because the thermostat is opening and closing properly and it just leaking past when closed its hardly noticeable during warmer weather
First thing to do is check if this is the problem. From cold start the engine. Put your hand on the hose by battery. Please be careful and keep your fingers away from any moving parts. The fans can come on randomly but there's plenty of space.
if it doesn't stay cold for a few minutes then the thermostat will be at fault.
I done three the same. The last one I unbolted the plate that holds the coil packs and moved them out of the way still connected. Cleaning the old gasket off was much easier.
Also you will see in the photo that one car has had a radiator leak and been filed with water
P0115 error
