im Axle Specialists
Old 23-01-2019   #1
Question 2004 Fiat Panda Dynamic Coolant Temperature Sensor Location
Hi there, My 2004 1.2 Fiat Panda has recently started showing a P0115 code and so I was going to check the Coolant Temperature Sensor, however, I can't seem to locate it.
I've taken off my air intake and looked at the back right end side of my engine but can't see it. I took several pictures however I can't post any links at the moment as I'm a new user. :/
If anyone can point me in the direction I'd be really greatful. Thanks in advance.
ScottEnock is offline Reply With Quote Quote
Old 24-01-2019   #2
Re: 2004 Fiat Panda Dynamic Coolant Temperature Sensor Location
at the back right hand side if stood in front of the car
pipe going into it and a green electrical connector
are you sure its not over cooling due to the thermostat. If the engine gets up to temperature then drops below 60C the ECU will throw up an error and put the fans on full.
easy enough to check the top hose again right hand side should stay cold for a few minutes when you first start the car. Its quite common for the rubber seal in the thermostat to perish and go missing
koalar is offline Reply With Quote Quote
Old 24-01-2019   #3
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Welcome to the forum
Even as a new user, you can upload pictures directly to the forum using either the Attachment or Gallery features. Full walkthroughs for these are in the Newbie Central section.
Eklipze3k is offline Reply With Quote Quote
Old 24-01-2019   #4
Thanks for the warm welcome! I've taken a look at the guide and have now uploaded the photos!
Thanks also for the information Koalar. I'll check the thermostat today. My coolant levels were a little low and so I'll top them up as well, do you think that could also have added to the issue?
Here's the photos I took. I can't seem to see a green electrical connector.
Engine Bay Without Air Intake:
Close Up:
Coolant Temperature Sensor?:
Old 24-01-2019   #5
varesecrazy has donated!
Hi. And welcome.
Your pics are centred on the FUEL LINES
Strangely I have never noticed my temp sensor.
There is another thread by @brooking147
Also sesrching for the same part.. they have a 14day headstart..
Charlie
Likes ScottEnock, brooking147 liked this post
Old 24-01-2019   #6
brooking147 has donated!
Quote Originally Posted by varesecrazy View Post
Hi. And welcome.
Charlie
Thanks for the mention..... and I am still looking !!
Well actually have not ventured outside much to have a serious look. Maybe at the weekend. I was trying to download the eLearn files to see if anything there helped.
Mine is a 1.1 with the same symptoms. I strongly suspect the thermostat but it does eventually get up to temp but can dip to nearly 1/4 on the gauge again in this cold weather. I wanted to check/ replace sensor first just in case and figured this was an easier option. I have a stat on standby too but thought a quick check of the sensor connections would not be wasted time first - when I eventually find the sensor that is .........!
brooking147 is offline Reply With Quote Quote
Old 24-01-2019   #7
to the left of the yellow cap
two coolant pipes go through the bulkhead to the heater matrix
follow the bottom one to where it connects to the engine.
you should just be able to make out a bit of plastic
there's only two bolts but you will need a new hose clip
it is also clipped in. I can't remember from which direction. I "think" After removing the bolts it has to be pushed upwards.
Likes ScottEnock, varesecrazy liked this post
Old 24-01-2019   #8
Quote Originally Posted by brooking147 View Post
Coolant temperature rising and falling is a sign of the thermostat sticking. The gauge is working fine, otherwise you'd not see the temperature changing.
Fit a new stat and see how it goes. As someone said elsewhere leave the rad cap in place and you will not lose much coolant.
DaveMcT is offline Reply With Quote Quote
Old 24-01-2019   #9
symptoms of a faulty thermostat
should fail the top hose test
rubber seal in the thermostat has perished.
Old 24-01-2019   #10
not shown in your photos but its about here at the back of the engine
Thanks ScottEnock thanked for this post
Likes SPORTPACK50 liked this post
Old 24-01-2019   #11
Ok. Thanks for that info
There is a FEINT yellow square drawn on that pic.
I had assumed by the directions given that it was coupled to the heater matrix tubing.
Old 24-01-2019   #12
correct. 95% certain its the bottom one.
Old 24-01-2019   #13
Quote Originally Posted by koalar View Post
This has bugged me..
Sure I must have come across it.
I went into HERE.
https://www.fiatforum.com/panda-guid...nge-gars4.html
Is it visibe
Last image ?
Thanks brooking147 thanked for this post
Old 24-01-2019   #14
just follow the matrix bottom hose
ID:	196851   Click image for larger version
Old 24-01-2019   #15
Perfect, answers my previous post too, thank you.
Need to get under the bonnet and sort things out now. Pretty sure it will be a new stat for me but good to know where the sensor is now too, just in case.
Thanks again....
(T) 1.9 Multijet - Coolant Temperature Sensor location? Gimba Grande Punto 3 26-03-2017 10:18
(T) Replaced MAP sensor and coolant temperature sensor SteveGriff10 Grande Punto 2 05-12-2013 20:05
(T) Ulysse 2004 JTD Temperature Sensor Fault / Location... KarlDyson Ulysse 0 22-04-2009 14:38
(T) Coolant temperature sensor location DanTech Punto (Mk2/2b) 1 06-05-2006 19:14
Inlet air temperature sensor or engine coolant temp sensor? Anonymous FIAT Boo Archives 7 24-01-2004 18:26
