- Jan 5, 2019
- 60
- 69
OK, so I have had my Panda for a few days now. Just wondering whether the movement of the temp gauge is normal or if I should replace the thermostat. It is a 1.1 8V petrol, 2009 ECO.
After a short time after starting the temp gauge rises to approximately 1/4 quite quickly then it looks like thermostat opens as it drops slightly. Driving approx 6 miles on varied roads but little traffic needle rises and dips slightly but stays around 1/4 mark or just above. Finally after about another five minutes or so it will rise again and then settle around 1/2 on the gauge.
Is this normal or do you think the thermostat is perhaps opening a bit early? What is yours like on the warm up? I would normally expect gauge to uniformly climb higher to 1/2 before dropping a bit then finally stabilise at 1/2.
Would replacement of thermostat be worth it? Or do I just leave it and see if it gets worse?
Have had leaky thermostats on other cars before but they tended to just take ages to rise off the bottom mark then never reached anywhere near normal temp.
I know about checking top hose to see if initially cold,which it is but does warm up after a few minutes of running.
Any thoughts?
Any thoughts?
