Oh dear, what a chaotic worker! I was not impressed! All that fluid leaking out was not good. If he manages to run the system dry he may end up with ABS unit bleeding problems. An old crisp packet jammed under the master cylinder cap or a hose clamp would quickly and easily stop it. Brake fluid is not pleasant stuff so having it drip on your T shirt? and what if you then transfer it to the paintwork? No, not impressed. By the way, I've been there and "done" the cheese steak - have to say I was less than impressed, but then I'm not a big meat eater.
I agree there is a place for heat when slackening corroded fittings but I wouldn't be doing this to the end of a rubber flex pipe. If you cut open the metal end of the hose you'll find that there is a central smallish diameter metal pipe which the hose is pushed over and then the outside is crimped over it all so compressing the rubber pipe onto the central spigot. That's all that holds it. Applying a lot of heat, which is bound to affect the rubber, is really not a brilliant idea. I'd be soaking the tube nut in Plus Gas (or PB blaster if that's your thing) the night before, then gripping the metal crimped part of the end of the flex hose with a Stilson or Footprint wrench to stop rotation whilst using a suitable spanner on the tube nut itself. If it still won't move then I'd give up on it and be using a flame on the other end of the flex to free the nut on the front to rear pipe and throwing the flex away and fitting a new one. That way you can get a bit more "enthusiastic" with the torch and just cut away the flex and the seized fixing on the other end because you're going to be replacing it. If a fixing is that corroded that you can't free it it's probably needing to be replaced anyway? - a flex hose is pretty affordable.
I really think you need to be very cautious with heat on braking systems with their rubber hoses and internal seals to say nothing of the danger of naked flame near fuels. Take care folks!
