Hello,
I'm new to the forums, so please go gently. I have very little mechanical knowledge, but a helpful other half!
I have a 2006 Panda, and have recently started having a problem with the central locking, which is key-operated.
When I lock with the key, it clicks as if it's locked, and mainly the problem is that it then clicks again, and all the doors are unlocked. I can't lock it at all at the moment. If I open each door the interior light comes on, and when I shut the door the light goes off. Occasionally, I've had the problem that it has locked, and the driver's door does not seem to be shut properly, then I struggled to unlock it again. I've also had the issue that locking the driver's door resulted in that door staying unlocked and the others locking. At times, the passenger door won't shut, because the handle is stuck in the pulled-out position on the outside (easily-remedied by pushing that handle back in from the exterior).
I'd be grateful if anyone has any ideas/what I should try to fault-find. Many thanks.
