- Sep 14, 2009
- 19,492
- 3,294
My 100HP has been woolly and twitchy on the steering for a while, but I needed to wait for the insurance claim to clear. The correct track control arms are pretty pricey for the 100HP.
Now, two new track control arms the car has its "on rails' handling back again.
A few tips for fitting them -
Jack the car up high. With a bit of care, you can lift the working side and use axle stands under the sill jacking points. Always chock the wheels and use softwood blocks slotted to clear the sill jacking point flange. I have a couple of 25mm battens screwed to 75x50 framing timber blocks.
If the car has an engine under tray - remove it for better access.
The track control arms have only three bolts each side so how hard can it be? The main bolts at the chassis end are easy to shift. But they are tight so you will need a 600mm breaker bar to get them started. Hence the need for space. They have 18mm AF heads.
The ball joint is held by an M8 pinch bolt (replace if damaged) but the arm will not drop enough to clear the ball joint pin. I put the jack under the steering ball joint and lifted the hub assembly until the front axle stand loosened. There was then enough space to drop the arm off the hub and get the arm away from the car.
Clean all bolts and coat end to end with anti seize paste. You might be doing the job next time. You may need to replace the ball joint pinch bolts. They are M8 high tensile so use lots of paste. The OEM are zinc plated but still better to be well protected.
Refitting the bottom arm is a pain to be honest. The back end doesn't really move backwards far enough to get the front bush into place so needs some careful persuasion.
Refit the big bolts. One or the other will be a right old struggle. Basically, if it's not lining up take the other one out and try again. If one goes in easily the other probably won't. Leave both with threads started but loose.
The ball joint will be miles away from the hub so you'll have to drop the jack. I clamped a long metal bar to the suspension arm with a vice grip (Mole grip) welding clamp. That gave enough leverage to push the arm down and get the ball joint pin into the hub. It's much easier with a helper but not impossible on your own. Fit the M8 pinch bolt to secure it.
The back shocks bottom bolts should only be tightened with the cars's weight on the suspension. This stops them being over twisted. At the front, good practice would put the jack under the hub until the axle stand is loose and only then tightening the front pivot bolt. The rear bolt is fine either way.
Now tighten everything and pack away.
PS - DON'T FORGET TO CHECK THE WHEEL BOLTS
