- Dec 29, 2017
- 32
- 8
Hello,
I have fiat panda 2006, 1.25cc
with SELESPEED CFC228F Automatic Gearbox
for the last few days i had a problem with code P0715 - Clutch disk speed, as i noticed thru monitoring the parameter that the clutch isn't fully engage, also i have the clutch overheated which make me believe that my problem lay in the clutch isn't being fully engaged,
the pressure is always ok and the problem lay low after the transmission oil temperature reach about 36, how ever i still get gearbox failed and the same error often when changing gears,
as an attempt to solve this i thought that maybe the clutch needs calibration,
i used multiecu scan to do Production/Service final calibration Adjustment but it keep saying "clutch stroke insufficient"
i remember changing the clutch disk about 3 months ago so i thought that may be doing the clutch replacement adjustment may solve this problem, however after doing that i now no longer can change the gear
not while engine on or while engine of, i don;t even hear the sound of the actuator trying to engage the gear.
what do you think i can do to solve this problem
even if just the latest one so that i can go to try my luck with any service garage
as a summary, i did clutch replacement adjustment using MultoEcuScan and after that i can no longer change the gear, using the acutator command i can engage 1 or 2 however i can't use that while the engine is on
thank you
thank you
