General Offside front widow
usually its the switch that packs in
i used to get spares at the scrappy and carefully dismount the top section from the passenger one and remount the drivers side one as drivers ones wear out first
be careful removing them from dash
Hi thanks for that checked the fuse all good there so looks like it be the switch then what's the best way of getting them in and out don't want to damage anything it's the missus car she go loopy if I scratch it
To test the switch you need to swap the connections at the switch. There is nothing to swap at the door end of the circuit.
