General Bonnet slam panel/rad support
DaveMcT
Distinguished member
Both should be fine, (unless you need a new horn) but...
You will need the spire clips from you old one (or some nice new ones) and also the sliding radiator retaining clips (pretty sure the 100hp uses a double one on one side which is different to the other models. Probably still intact on your old one, so just swap over)
Also, there are a couple of brackets at the bottom which will need swapping over. Think they are for under tray, but you'll see when you get to them.
I've got one, but I'm in Norfolk, so not necessarily worth a trip just for that unless you're local.
If you check with a few scrappies, they have been known to let them go for £20 or so, if you remove it yourself (on cars where they've already removed the radiator). Note that 17mm and 10mm bolts on bumper reinforcement can be a bit tight, socket & extension rather than spanner is wise.
Looks like I have found one.
Now need headlights.
Insurance is assessing the car on Tuesday but I think it will go into the "not economic to repair" box. So I'm planning to buy it back but you never know.
