Anybody have an idea of what this job should cost ?
2004 Panda 1.1 Active
Manchester area
Shocked how cheep that is tbhMine had a failed heater matrix..
did 2 x HG.s in 6 weeks..
£10 gasket. £40 bolt set.
Allthrough sounds like you needed it to bw
If the radiator is old you might as well change that at the same time. It's more likely to be the real cause of the problems.
Also check the inlet manifold is ok. The material is same to 100C but not much more.
