Ciao Babbo, come stai?
Sto bene grazie. We're at our Umbrian home for a couple of months, having arrived via a concert gig in Sardegna on the 1st of September.
My previous Panda was a 100HP, which I was very fond of. The rear end was a victim of Fiat's habitual weak return damping, but adjustable Konis on the back made a big difference. The half mile of steep white road to us here has deteriorated horribly over the last three years or so and the 100HP couldn't tackle it, though the 4x4 TA's fine. Beginning to look for something like Konis for the 4x4 but have found nothing so far.
My Fiat 500 springs are stuck in the DPD system. I will have to chase them later.
Cars have really quite heavy axles and wheels so do need good dampers to keep it all under control. Ideally minimal damping on impact but increasing as the wheel moves up. Then strong damping on the return so the wheel does not smack down after the bump.
A sign of weak dampers is a double thump over road bumps. One caused by the bump, the second caused by the wheel coming down too hard.
Fiats have tended to have weak rebound damping over the years especially on the rear - which is why I've spent so much money on Konis - 131 Sport, Ritmo Abarth 130TC, Uno turbo ie, Cinquecento Sporting, Panda 100HP.
HI Ian
Your place sounds like Torquay. Where it's not infested with speed bumps it feels like they just tarmacked over the bedrock. Where the roads are clear they are potholed just to keep you on your toes.
My wife's 1.2 with it's 500 rear axle rides so much better than standard its really quite amazing. The 500 springs are 30% softer than standard 169 springs. The axle has a built-in anti-roll so it's stiffer when one wheel hits a bump. That has no effect on (such as) speed bumps where both sides move at the same time. That's where bump stops come into play.
Ride height was a little lower than standard 169 but adding a rubber spring seat to both ends of the springs brought it level again.
For the 100HP, I'm thinking about 500 springs with rubber spring seats on both ends but expect that to ride a little high and maybe a bit too soft. But shortening the springs to bring it to 100HP height might stiffen them just enough.
Used springs are not silly money on eBay, so it's worth a try.
The front struts are more of an issue. The top names are very costly and TBH a gamble because it's not clear how stiff they are or how much they are lowered. -30mm is fine but not on a 100HP that's already lowered. So what's their start point? Sellers don't seem to know.
Minor names like Pro Sport are not low cost but are they any good? Who knows - and their spring stiffness is anyone's guess.
Hi... Have you got a link to the rubber seat spring plz
They are on ePER Fiat ref 46843237 "Thrust ring". Panda or Fiat 500 rear springs on eBAy often come with the rubber seats. You will have two on the car, so if going for used 500 springs, just get a pair complete with rubber seats.
Eper shows the bump stop at the axle end. On both of my Panda's, the stop is at the top end. The 100HP stop is too long adding to the harsh ride.
These look ok. https://www.ebay.co.uk/itm/2015-FIAT-500S-1-2-REAR-COIL-SPRING-PAIR-PETROL-8997/253324983592?fits=Car+Make%3AFiat%7CModel%3A500&hash=item3afb587d28:g:7dsAAOSwUchaPOti:rk:9f:0
If you want to stop standard springs rubbing the axle pans you can slide some reinforced rubber hose along the spring. You need to get the correct hose size but 15mm bore will do the job. Use lots of red rubber grease so they cover one full coil plus another 1/4 turn.
...Who knows why Fiat use a bump stop with a 75mm of uncompressible material and a soft part only 40mm high....
It's to limit body roll without having the cost of an anti-roll bar. Car sits on the bump stops on hard cornering, which isn't ideal if the road isn't smooth.
I'm running Eibach springs on standard shockers. Sits 20mm lower but there's no issue with ground clearance. Handling is just as good, ride quality is massively improved.
