Thread Tools
Old 14-09-2018   #1
Exclamation Knocking/Vibration noise after new Brake Caliper fitted
I'm getting a knocking and vibration sounds when I'm in 4th gear usually when going over drain covers or bumps.
The brake caliper was replaced on the front left. The noises only occurred after it was replaced.
I'm not 100% trusting of the mechanic who done the work as he seemed to rush the job. He's a mobile mechanic if that helps.
Could it be loose or the caliper bolt not tight enough?
Thanks.
mattwick92 is offline Reply With Quote Quote
Old 14-09-2018   #2
Ireland
Re: Knocking/Vibration noise after new Brake Caliper fitted
I'd jack it up,, pull off wheel and have a look .I had an intermittent similar issue and it was just the brake disc thin metal shield rubbing off disc occasionally - easy to bend back a bit ) .But I wouldn't ignore it . I think Fiats have a higher than average tendency to become 3 wheelers !!!! I had a 98 Punto Sporting do it once after a few days 'wheel bearing ' moan ... :-(
ytareh is offline Reply With Quote Quote
Old 14-09-2018   #3
Quote Originally Posted by ytareh View Post
Ok thanks for your advice I think he's coming tomorrow to see if he can fix the noise problem.
Old 14-09-2018   #4
Ireland
At least he's not washing his hands of it so that's a good sign .Let us know how it goes .Mechancs can walk away from costly errors and it's rarely customers get satisfaction .I took a 3250 hit on a cowboy garage blowing up a 1.2 TSi engine after shoddy timing chain replacement .Told no point trying to pursue them ...
Old 14-09-2018   #5
Trader Rating: 1
portland_bill has donated!
There's a spring plate in the caliper to hold the pads tight in their carrier. New caliper will not include that, needs to be swapped from the old one. My guess is it is still in the old caliper.
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 15-09-2018   #6
Well he's just finished and it turns out he fitted the wrong caliper as the bolt was loose. I'm going to use a garage in the future to save the stress
Thanks for your answers !!!
Old 15-09-2018   #7
Trader Rating: 1
No matter how urgent, never use this guy again. Perhaps he's a mobile mechanic because no-one will employ him. Checking the replacement is correct is a fundamental part of any repair, but especially important when working on safety critical areas, like brakes.
Glad its all ok now.
Likes jrkitching liked this post
Panda Alessi
Old 15-09-2018   #8
Quote Originally Posted by portland_bill View Post
Your right definitely not going to as he wasn't courteous about the job anyway!
At least he didn't charge me too much (140 Inc refurbished caliper and labour).
Old 15-09-2018   #9
There are two makes of brakes fitted to the car. Bet the wrong part was ordered and/or arrived. They look very similar. In fact when I checked the motor factor said there is only one set of pads listed so they must fit both.
koalar is offline Reply With Quote Quote
Old 16-09-2018   #10
Quote Originally Posted by koalar View Post
One fits better than the othere. Eurocarparts was the first one and the bolt wasn't a good match. The second one was slightly smaller caliper and fitted perfectly. I think the reason for it was because of the caliper bolt being different sizes.
Thread Tools
(T) Strange vibration and noise from front driverside brake Chris017 Stilo 5 01-09-2012 00:24
(T) Knocking noise when I brake trini Bravo 4 29-03-2012 15:42
(G) Knocking/vibration Bougainvillea Rosso Panda (Classic) 3 21-11-2008 19:19
(G) Vibration/Knocking ginner Cinquecento / Seicento 2 23-07-2008 12:00
(T) brake caliper noise? mqsash Uno 9 06-01-2007 23:53
