mattwick92
Member
- Nov 23, 2015
- 77
- 71
I'm getting a knocking and vibration sounds when I'm in 4th gear usually when going over drain covers or bumps.
The brake caliper was replaced on the front left. The noises only occurred after it was replaced.
I'm not 100% trusting of the mechanic who done the work as he seemed to rush the job. He's a mobile mechanic if that helps.
Could it be loose or the caliper bolt not tight enough?
Thanks.
Thanks.
