Are you going on a long overland rally/tour?
When my 100HP hit a deer, the animal (not surprisngly) smashed the bumper but also (IMO very surprisingly) bent the main and air con radiators.They are in fact protected only by flimsy plastic that keep the weather off but little else. A steel tube hoop bolted to the solid steel under bumper would better protect the tops of the radiator. You would need to remove the front bumper to see my point but well worth a look at your car.
I got away with a bent air con rad (that still works) but any more damage would have totalled the main rad and spoiled my day even more.
The impact also shattered the headlight and radiator supporting "slam panel". Something to protect that would be sensible as you can't drive if the bonnet won't latch and/or the headlights are at wonky angles.
