Thread Tools
Old 02-08-2018   #1
Germany
HP100 suspension dust cover / rubber buffer
Hi there,
I'd need help to find the right rear suspension dust cover/buffer for my 100HP Panda. Whereever I've searched so far it always say it doesn't fit for the 100HP and I just can't believe that.
Does anyone have experience if it's the same like for all other Panda Type 169 or are they really different? Even better would be if someone cold recommend where to buy it or just post a shop-link..
The FIAT Part-Nr./OEM should be 51811829
Thanks !
NL1993 is offline Reply With Quote Quote
Old 02-08-2018   #2
Netherlands
Re: HP100 suspension dust cover / rubber buffer
Dustcover? Or do you mean bumpstop?
Dealer must be able to order it, but the car runs fine without them
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Old 03-08-2018   #3
Use the standard Panda bump stops. The ones fitted to my 100HP (which I believe are OEM) are just too long and too hard.
DaveMcT is offline Reply With Quote Quote
Old 10-08-2018   #4
Use the fiat Coupe bump stops from shop4parts they are shorter than the standard ones that are prone to snapping off.
littleted is offline Reply With Quote Quote
Thread Tools
(G) Rubber Buffer replacement creon Doblo 0 13-12-2015 12:54
(T) suspension arm ball joint dust cover tuftyone Ulysse 3 15-08-2013 12:48
(G) 02 reg Front Suspension arm dust cover - can't get ball joint back in! fern1515 Punto (Mk2/2b) 32 13-08-2012 11:00
(G) Suspension Dust Cover ? Punto Dkn Punto (Mk2/2b) 0 13-02-2009 13:55
(G) need a rubber buffer Mayhem Grande Punto 2 06-02-2009 15:13
