Does anyone know for a fact what causes the 1.1 misfire? I've read about it but not found a definite answer.
Mine does it occasionally. IE can drive perfectly for a while then it can start etc. Then the car runs fine again. Only seems to happen at 40+ mph now. And it doesn't go on for long IE just a couple of misses then it's fine again.
I believe it to be an ignition fault as it happens so quickly.
No fault codes are ever stored either.
Car is a 2010 1.1 with 107K miles with full service history and I'm the second owner.
If this issue is so common..do FIat know about it? Mebe they have a fix?
Thanks all
Thanks all
