Woke up to sunshine streaming in the bedroom window this morning. No grandchildren today and Mrs Jock has her own "stuff" to do. So, after taking her a cup of tea and a biscuit to enjoy in bed (I really know how to treat a girl!) I decided to do some more "bonding" with Becky and see if she'll surrender some more secrets. My BOC cylinder hire bill was due to be payed so we set off for the local depot only to find it had closed down! Is nothing sacred! then up the road to Toolstation for some self amalgamating tape to wrap Becky's perished breather pipe. (I feel a Shop4Parts experience coming on). Then back along the sea front, through Leith and on past Newhaven to the big Morrisons to refuel (Mrs Jock collects the points) and so home. All the time feeling and thinking about the steering thing. - And feeling very pleased with the other aspects of how she's driving.
The more I drive her the more I'm convinced the effect I'm feeling is due to a "tightness" in something. Rack, Top mounts, I don't know, but not bushings and probably not ball joints.
Mrs J was busy with sewing things so grabbed a coffee (Aldi Cappuccino actually) and sandwich and went and sat on the ground beside Becky's OSF wheel whilst I munched. Now I've had a fairly good look at her front suspension when I was working on the timing belt but not to the extent of actually, close up, for a number of minutes, looking closely at a front tyre. I had pulled in with a lot of lock on earlier so the front tread was fully exposed. This is what I was confronted with as I drank my coffee and it got me just mildly excited.
So what was I looking at? Well first off the outside tread edges are more worn down (less depth of tread) than the inside. This as a stand alone observation may not be significant as you would expect to see that if the car had been cornered hard by the previous owner. However if you look very carefully you will notice that on each block of tread the edges to the left are slightly rounded off and the edges to the right are very sharply defined. Now if you take your fingers and rub them sideways, to and fro, over the tread, feeling the edges of the pattern as you go,
you should find both edges feel the same, but in this case the inside edges felt much more "catchy" and "sharp" than the outside. Now I examined the other front tyre and found it to be the same, outside more worn than inside and rounding of the outside of the tread blocks with "lipping" of the inside edges. This is a classic indication that the toe is wrongly set. In this case the symptoms indicate too much toe in (in other words the front tyres are snow plowing down the road, or, to put it another way the front wheels a knockneed! If the wear pattern is reversed there would be too much toe out which means the front wheels are splayed out. A further indication in this case is that the wear pattern on the NSF tyre is a little worse than the OSF which is logical as road camber causes you (and you don't really notice it) to steer, very slightly, to the right so the left front will exhibit more wear. This effect is reversed if you've got too much toe out.
So. OK. looks like my Toe settings are incorrect, but is this due to wear, or maybe damage to a component in the steering, or actually being set up wrongly, or what? I spent about an hour going very carefully over everything I could get my hands on, pushing, pulling, levering, twisting etc also checking for damage to ball joint rubber boots and components themselves (ie is something bent?). I was very pleased to see how good those front brakes are looking.
If you remember what they looked like when I stripped them, why, it's nothing short of a miracle! I was less pleased with the front road springs which look a bit rusty and the underneath view of the top spring mounts which also look a bit rough!
It was whilst looking at the front springs and the, somewhat limited, view of the spring top plates, that I went "up top" to examine what can be seen of the top mounts under the bonnet. Close examination clearly shows that the OSF top upper mounting cup Mr Haynes name for it!) is well proud of the body work
when compared to the NSF one, which is itself showing some clearance.
question for any knowledgeable gentlemen who might be reading this. should the cup be hard against the tower when new or will there always be some gap?
Where is all this leading I hear you ask? Well, I think I may have found the culprit behind the strange feel to the steering. I'm very suspicious of that OSF top mount. It's protruding much further into the engine bay than the NSF one. I think It'll have to come apart for inspection!
I've got a lot lined up over the next month or so though, so it's going to be a wee while before I can get stuck in. However, as I mentioned somewhere before, I have my own home made tracking gauge - a demonstration of which I have threatened to inflict upon you! So, now that I suspect Becky to be carrying a little too much toe in (The effects I'm seeing are not extreme so I don't think she's far out though) I'll use the gauge to check what she's set at right now. Correcting it, and I'm sure it will be needed, would be a waste of time before I refurbish the top mounts/springs/struts/and whatever else I find when I strip it all down.
I'm going to do the bit about using the tracking gauge in the "Tech Talk" section as it could be applicable to most cars. Might get time to do it tonight, maybe?
Regards to all
Jock
