Zoikarios140
- Oct 12, 2013
- 33
- 11
Hello ,
After tyre replacement and wheel alignment my Panda goes straight but if I keep the steering wheel straight it goes to left ! From 2 wheel shops the wheel alignment machine shows that the car is perfect. I noticed that the steering wheel doesn't have "tooth" when you remove it and re-install it. If I loose the nut and alignment 1mm with the hand I will make problem with the sensor or not ?
