Oh deary me, that truly is a horrible and maybe expensive sounding noise! The frequency is about right for something to do with the valve gear, it doesn't sound like it's a bottom end problem but I doubt very much if you're going to sort it by adjusting valve clearances. As you are moving your phone around the noise seems a little louder when you are at the clutch end of the engine so does the sound alter if you put your foot down on the clutch with the engine running? That would eliminate clutch/gearbox (which I don't think it is anyway). I would like to stick my "listening pipe" in my ear and move it around the engine till i found where it was most noisy, but it's not long enough to reach you from Edinburgh! So, what to do next? Well, as it's simple to do, I think I'd be taking the cam (rocker, in old language) cover off and having a look. The noise is so loud that I'm sure anyone with some experience who could stick his/her head under your bonnet would quickly come up with an answer but, from Edinburgh, it's a bit difficult.Hi,
My Panda starts making an irritating noise just like this https://www.youtube.com/watch?v=_kQCHTYWZwQ
Can anyone please tell me if the solution to this is to adjust the valves or if I need to do something different?
Thanks a lot for your help.
Thanks a lot for your advises. I will start by adjusting the valves and see what happens. The car runs well, only the noise...So many thing cause that type of knocking noise.
Stick valve normal goes away when warmed up.
Connecting Rod normally worse under load
Mine makes a more of a tick tick noise than the clunk clunck in the video which is due to a crack in exhaust heat shield.
Before delving too far into it you need to isolate from where the noise is coming from. Last thing you want to be doing is ripping the head apart only to find out it was a broken bearing in the alternator
I was going to support P B's suggestion to remove the cam cover and have a look (I also recommend this when I posted a week ago). However I see you said that you had "adjusted the valves" and that it "wasn't too bad"? If you'd said "I checked the valve clearances and that wasn't too bad" I'd accept that but adjusting valve clearances on these engines is a laborious task involving shims, and specialist measuring tools. I did it on my old Panda (Felicity) when I rebuilt her head after she blew her head gasket and I remember one of the most frustrating things being actually getting the shims I needed! But my point here is that you must have had the cam cover off to work on the valve shims? So what did you find inside? Nice and oily? No obvious damage to cam lobes or followers? Do please let us know.Thanks to all for their input. I have cleaned the injectors using a LiquiMoly device and product that is made for that purpose, adjust the valves (wasn't so bad) and wash the throttle body. This is the noise I got.
https://www.youtube.com/watch?v=OrsAz_Lu--E&sns=gp
Any idea what can I do to find out what it is?
Thanks.
