Hello
I hope some of you might be able to help me decide whether to buy a 2010 Eleganza or not. It is in good cosmetic and mechanical nick, low miles (under 10k) with decent service history.
I've read many of the posts on here which have been informative and helpful. I have two concerns and related questions: -
1. How common are the climate control/heater problems that affect Eleganzas and 100HPs? I have read about the plastic gears breaking resulting in no hot air. And experienced the problem where you have to jiggle with the fan speed and other controls to get hot air myself on a car I owned for a short time. (I posted about it here and ended up returning the car in part as a result of the helpful answers I received.)
Do some cars have a long and happy life without a heater problem while others are affected after a few years/miles?
Has anyone done a survey?? Does anyone have a feel for what the odds are of these cars will become problematic? 3:1, 30:1, 300:1...3000:1?
Or is it more the case that most/all are affected and it's down to use - a question of wear and tear? If it is, what kind of mileage do the problems start to appear?
I like the refinements of the Eleganza but if the the heater becoming a problem looks more likely than not, I'll look for a different model with the simpler set-up.
2. How bad does the suspension cup look in the attached photo of the car? The axle looks fine - just some surface rust. But the suspension cup looks worse. Should I be worried? Walk away? It looks like it might be solid underneath - although it is flaking a bit, it isn't coming apart in layers the way badly rusted metal looks. But I have no experience with Panda axles.
If I do get it, I would follow the advice from forum members of wire brushing it down and covering in something like thinned chain oil, waxoyl or combination.
(The suspension coil/spring looks pretty bad too but I'm not as worried about that because it is easily replaced.)
Thanks in advance for your help.
