Does anyone happen to know what voltage the injectors run on for the 1.3 multijet engine? My one is 188A8000. Injectors have part number 0445110083.
I know some run on alternator voltage, some on much lower voltage (3V or so), and the peizo types on several hundred. I stupidly forgot to put a voltmeter across the pins before I took the engine out, and now I won't be able to test until everything is back together again!
If anyone knows what they run on, or has the same car and could put a multimeter across the pins that would be really helpful. Thank you!
