Thread Tools
Old 10-02-2018   #1
12v constant supply
Hi all I need to fit a switched live socket in my Panda. IE not off the key. On my late punto it was easy as there was a permanent live male connector in the internal fuse box.
I haven't spent much time looking..but my Panda is different. I was wondering if anyone has a quick easy answer?.) I'm being lazy so thought I'd just ask to save me messing around
On my punto I just fitted a switch and an extra cigar lighter socket to run my sat nav phone charger and dash cams etc while my car was off.
Thanks in advance guys
Nickhmh is offline Reply With Quote Quote
Old 10-02-2018   #2
HP
I was only doing 80...
HP's Avatar
HP has donated!
Re: 12v constant supply
In the fusebox by your knee there's a big fat red wire feeding in. As long as you're not drawing a massive load, you can tap off this. Make sure you don't cut into it and join it as it needs to still supply a good amount of power to other circuits.
Likes Nickhmh liked this post
Pete.
"Make something idiot proof and someone will just go and build a better idiot".
HP is offline Reply With Quote Quote
Old 11-02-2018   #3
Just the other side of the glove box (RHD) is the battery. Just make sure you add a inline fuse.
koalar is offline Reply With Quote Quote
Old 11-02-2018   #4
I fitted a cig lighter in my panda, i brought the wires in from the battery (fused) near where the passengers feet, under the carpet, there is a small hole, i passed the wires through the hole and hid them under the carpet, bit fiddly but it worked well.
Stavros2 is offline Reply With Quote Quote
Old 11-02-2018   #5
I run my dash cam off a power bank. sits nicely in the ducket above the radio.
Wee Doogs is offline Reply With Quote Quote
Old 12-02-2018   #6
Quote Originally Posted by HP View Post
Thank you
Old 12-02-2018   #7
Quote Originally Posted by Wee Doogs View Post
Good idea! But I run two dash cams..front and rear plus phone and laptop and e-cig s. So I really need a separate charge connection. Will be looking at a direct battery switched socket really. I'll also be upgrading the battery and alternator from my Punto..I have a larger battery from a 1.9 Diesel punto and the larger alternator too..
Likes Wee Doogs liked this post
Old 12-02-2018   #8
Quote Originally Posted by koalar View Post
Thais is probably what I'll end up doing mate do I need to remove the carpet or can it just be pulled down in the foot well?
Old 12-02-2018   #9
Yes found this large wire. I'd prefer to come off battery and not interfere with it TBH..thanks all the same mate
Likes HP liked this post
Old 13-02-2018   #10
Cheguava has donated!
Hi, probably worth looking at this post. https://www.fiatforum.com/panda/2238...1=#post2378734
That's how I fitted mine, and it ended up as a nice tidy installation. Hope it helps
Cheguava is offline Reply With Quote Quote
Old 13-02-2018   #11
Looks nice and neat
Old 13-02-2018   #12
Quote Originally Posted by Cheguava View Post
Thanks mate!
Thread Tools
(T) Permanent 12v supply Andyf99 Fiorino (Mk3) 1 08-01-2018 21:26
12v constant and amp help please daz90 I.C.E 8 02-08-2010 22:09
(T) 12v constant Trist Punto (Mk2/2b) 4 24-05-2009 01:46
12V Power Supply. Roberto FIAT Boo Archives 10 21-05-2006 21:41
(S) 12v Supply safeguy Punto (Mk2/2b) 2 05-03-2006 12:54
