Hello
I've just bought my first Panda (54 Eleganza, Dualogic) at the weekend. The bodywork and interior are in great condition. It has FSH and was serviced every year according to the handbook despite low miles by the first owner of 12 years. The second owner did 12k miles in 2 years of ownership and did one large service in that time - not quite as pampered, but decent servicing by my reckoning. The dealer I bought it from did an oil and filter change before the sale.
It drove faultlessly in the test drive and on my 40 mile journey home. So far so good. I was over the moon with it and spend the next day washing and polishing it.
Over the last couple of days of driving it however I have noticed a few problems. I've spoken to the mechanic at my local garage and read several posts here and I know the cause of the first problem, don't know about the second and the third is trivial/an easy repair I hope.
1. The heater isn't working properly. It behaves exactly as described in a few threads on here when the plastic gear is broken.
2. The Eco button on the gear unit doesn't work - the E doesn't show on the dash display and the car's gear change isn't affected. It doesn't work in short.
3. The central locking doesn't work on the rear passenger door.
My questions are: -
1. Are either of the first two problems likely to lead to worse problems down the line? (It sounds like the Eco mode can be achieved by short shifting manually so I don't mind it not working. Although I would prefer it to work of course - so if anyone knows what the problem might be, please let me know.)
2. How difficult is it to live with the heater as is? (It seems tricky to me but I've only lived with the car for a couple of days. If I wack it up to full fan speed and jiggle with the direction controls, I hear something shift into place and get hot air. But when I lessen the fan speed, the air blows cold after a couple of minutes. Which means constant attention - seems like a pain in the bum.)
3. Should I cut my losses and get a refund and look for a car without these problems? (Bearing in mind the general condition of the car apart from the problems I've listed.)
(If I do go for a refund and look for a different car..)
4. How prevalent is the heater problem? I really fancy an Eleganza because I prefer the 2nd generation Panda shape and like the dual sunroof and alloys. From the threads I've read, I know that the heater problem affects the Eleganza and 100HP models with climate control. Would I be better off looking at Dynamic models fitted with alloys and sunroofs to avoid the problem?
5. Should I avoid dualogic? Is it reliable/prone to problems? I like it and prefer it to manual - seems ingenious and like the best of Auto and Manual. But I'd go for manual if it meant increased reliability. (My mechanic's advice is to avoid dualogic.)
I realise that's a lot of questions for a first post! If you only have answers/suggestions for some of my questions, I'd welcome them.
Thanks in advance for your advice.
My questions are: -
