Whiffy smell in cab, had that, check the copper washers on bottom of injectors for the dreaded black death gunge.
Then Smokey Robinson problem. As too doon the back of that engine, quicker and safer, removing the engine sorry to say. Changing EGR is a pig. EGR Cooler just as bad. Inlet manifold is main problem as some of the bolts are fitted and removed without sight. Why remove manifold, cos mine was full, plugged, with carbon black. Then there was the inlet tracts in head, how does the air get in there with it that bad, scrapper required and vacuum sourse. At start car was going well, excellerating well, but smoking badly.
