FIAT Auto Specialist Team
Old 30-10-2019   #16
varesecrazy has donated!
Re: Pandas EGR valve
I suspect the thermostat isnt great.. but looks quite involved to change..
imagine all those 12 year old hoses failing once disturbed..
Old 31-10-2019   #17
It's not a big deal to change. You need a 10mm socket and extension. Remove the coil packs for access and there's the thermostat held by two 10mm head bolts. I removed the ECU for easier access but even that was just more10mm bolts. Hoses are fine but you will need suitable worm drive clips.
Running the car with stuck thermostat costs petrol, is bad for the engine and the exhaust catalyst.
DaveMcT is offline Reply With Quote Quote
Old 01-11-2019   #18
Ain't no coil packs on a diesel.
You can see the egr mechanism if you remove the top part - working from above, not underneath - but to clean out the egr is a bigger job, because the whole thing has to be removed.
Not convinced that your problem is egr-related. Sounds more like a leak of fumes into the cabin because of an underbonnet leak.
When was your's last serviced? Does the car still perform well, or has there been a performance drop-off? The turbo hoses go flabby with age and can split. Worth checking them.
Sweetsixteen is offline Reply With Quote Quote
Old 01-11-2019   #19
Im laid.up currently ..
But would love to get under the car and sort this out.
Its all stock.. is due an oil change too.. but has generally run well.
Old 01-11-2019   #20
OOPs
Old 02-11-2019   #21
Old Gitt..
goggs has donated!
Whiffy smell in cab, had that, check the copper washers on bottom of injectors for the dreaded black death gunge.
Then Smokey Robinson problem. As too doon the back of that engine, quicker and safer, removing the engine sorry to say. Changing EGR is a pig. EGR Cooler just as bad. Inlet manifold is main problem as some of the bolts are fitted and removed without sight. Why remove manifold, cos mine was full, plugged, with carbon black. Then there was the inlet tracts in head, how does the air get in there with it that bad, scrapper required and vacuum sourse. At start car was going well, excellerating well, but smoking badly.
goggs is offline Reply With Quote Quote
Old 03-11-2019   #22
Quote Originally Posted by goggs View Post
Injectors too far down back of engine.??
Ive got the 1.3.. pretty sure theyre on top..
Old 03-11-2019   #23
The clogged inlet manifold is a not unusual on diesels which are largely driven slowly or at town speeds. The EGR is running full bore and airflow is not fast enough to keep the inlet manifold clean.
The excessive smoke will quickly wreck any exhaust filter fitted to the car.
Many cars have the inlet manifold so tightly tucked it, its easier to remove the engine for removal of the manifold.
Old 08-11-2019   #24
Old Gitt..
goggs has donated!
Hi again got caught up in my Oxygen hoses. No the whiffy smell in cab turned out to be the easy job. One injector was noticeably leaking a mess, while other was starting. Thought we would cure exhaust smoke as well by changing injectors but it pays you to just do spill test.
Down back is of course where, inlet manifold stays and EGR. End of inlet manifold removed and this black thingy stuck its head out. That was the start of tedious manifold/EGR removal, cleaning, swearing, etc.. EGR renewed, second hand cooler and MAF.
Did ECU tests with Multilicious (sounds better) and nothing really altered before and after except EGR being open 0.030". (I'll get on here later).
Old 15-11-2019   #25
Get a wriggle on!
levemircento's Avatar
levemircento has donated!
hello, I have 1.3 grande punto, recently had whiffy smell in the cabin, it was the injector seals [I done a guide on here if you look it up], if you can get access to the top of the engine while its running drop some water into the trough where the injectors are, if it bubbles up the seals are gone
must be time for a brew
levemircento is offline Reply With Quote Quote
Old 15-11-2019   #26
Quote Originally Posted by levemircento View Post
Thanks.
Water in the wells..
See my post in tech section..
its a GP too
Charlie
Old 15-11-2019   #27
Quote Originally Posted by Sweetsixteen View Post
All the how to's I read seem to Say :
drain coolant.. then remove and clean the EGR..
BUT can I just unbolt the finned section?
Draining no coolant..
See my pics in Tech section
Old 16-11-2019   #28
The finned part is just the solenoid. Once you take it off you'll see a small plunger in the end. You can't clean anything just taking that off, you'll have to take the whole egr valve out.
Cinq999 is offline Reply With Quote Quote
Old 16-11-2019   #29
Quote Originally Posted by Cinq999 View Post
Cheers..
Not even enough space to gauge crud levels?
Does the coolant definitely all need draining?
Not able to swing it around on hoses?
Old 16-11-2019   #30
When the solenoid is removed, you can see the plunger and spring which opens/closes the egr, but no access into the valve itself.
Only way is to take the entire valve out. I also think the coolant pipes definitely have to come off, there's virtually no room to move, let alone clean it.
I had a mechanic take it off along with the inlet manifold soon after I got the car, and it took him several hours. It was such a pain, when the egr died earlier this year, he didn't want anything to do with it.
(T) Egr valve.. where is it allan jenkins Bravo 1 08-11-2016 18:46
(G) Replacing malfunction EGR valve with aftermarket EGR luka78 Bravo 2 18-06-2016 18:51
(G) EGR Valve - Anyone need a new one? 77jm Punto (Mk1) 1 07-04-2010 16:48
(T) Egr Valve (or overboost valve?) zipuk Stilo 19 29-08-2008 20:38
EGR valve, is there one?? new to hgt FIAT Boo Archives 2 18-02-2006 13:11
