PB - experienced drivers with a good working knowledge of Panda characteristics, like yourself, might feel comfortable testing steering your way, but many reading your suggestion are not so knowledgeable.
It's not worth the risk on a public forum to suggest anything that is not fail safe. Hence my advice to try a different method.
:yeahthat:
The car will drive perfectly safely without power assistance to the steering and/or brakes, but that does not mean the driver is safe to drive it that way.
IMO all drivers should get some experience of driving the car with the power functions disabled (it could even save your life), but such experience is most appropriately gained on a private test track with a qualified instructor. Sometimes there's a fine line between training for an emergency, and causing an emergency by training.
You can still stop the car in the same stopping distance without servo assistance, but the pedal pressures will be
much greater - someone facing this situation for the first time might incorrectly conclude that the brakes had locked solid and failed. Also, the Panda is known to be somewhat weak in the pedal area, and I wouldn't want to unnecessarily stress that mechanism without good reason.
If you choose to disregard all these safety warnings and try driving the car with the engine switched off, be
absolutely certain that the steering lock can't engage or you will crash for sure. I know personally one driver who dealt with a throttle stuck wide open by turning off the engine and pulling out the key (basically they panicked); they demolished a garden wall shortly afterwards when the steering locked solid, fortunately without hurting themselves, though the car was a write-off.
The importance of doing basic checks before driving away can't be over emphasised. Thanks to a mistake by the service department, I once drove a car off a forecourt which had no brake fluid in it; I didn't realise until the first time I needed to stop and the pedal hit the floor. Fortunately I was (just) quick enough to catch it on the handbrake, but I've never again driven anything off without first testing the brakes.
