The resistor and capacitor termination was one "fix" that stops the DC load on the CAN bus but still loads the data signal. There is something more fundamental:
What year Panda do you have and what engine does it have?
The ATSPC command is trying to connect to the CAN bus with a custom profile and it's posssible you car does not support it. Was the car a used import or was it built for the Jordanian market? I was last in Jordan twenty years ago and there were many imports but I'm sure things have changed.
Robert G8RPI.
i have panda 2006 with 1.25 engine
in the
MES it's named as panda 03' 1.2 8V and the engine control unit i think is magneti marelli iaw 4af/4ef/59f/5af injection (outside EU) as it's the only one having just 2 coils in the simulation (not sure)
any way i have bought this car about 3 months ago
i don't know it's origin if the chasis number helps i can provide it tomorrow
and it was working like a charm for 1 months then i had to do an overhoul for the engine because of the previous owner used oil was i think way past the exp date anyway
after that it worked fine for a month then i'm stuck with this problem for a month now
i think the problem happened maybe when they where trying to mount the engine as the have the gear left in place and when i was there the mechanic had a hard time mounting it and then he thought about taking the gear out then mounting it with the engine all together
any way he started to take the harness out then he told me that he can have a friend help him if i'm not in hurry and the next day it was done but i don't know what happened
any way i had it scaned that time a with a g2scan (i think that was it's name) and i rested the service and it worked great there was some error's and the recommendation was to change the clutch disc (the problem i had that time was the same problem i had from after a week from buying it and that it was the gear goes to natural while driving )
when i had my current problem i had one scan it and try to fix it and he said that the ecu is out and i need a new one
as he said that there was a tps problem and after changing the part the error still there and that means the ecu is out
but as i know there should be a problem in the harness when that happen so i took the car and started working with my self
i found some damaged wires and broken fuses , these where supposed to be found by the same guy who scanned it so i had no faith i decided to do it my self
and as i know the only thing they new about the scan is extracting error no live data
even the service rest i had a hard time convincing the guy to let me do it
they won't let me do the actuator test or something like that (it's very hard and if i need to work for a good time with it i had to have my device)
20 years ago i think fiat dealership was with the same company i work for now Abu Khader group
but now it's with another company and they said they don't work on this model as the devices the have won't connect (they said that on the phone when i called to book)
that's the whole story
if there is any fix for the elm327 i can do it no problem and i can upload the board pic tomorrow
thank you
