Old 29-12-2017   #1
coolent flush
hi, got a 2008 fiat panda and thinking about a coolent flush and renew all antifreeze but dont know how much antifreeze to put in,got antifreeze from shop red in colour and they say 2 litres will do,does this sound right to you thanks lee
lee hughes is offline Reply With Quote Quote
Old 29-12-2017   #2
Trader Rating: 1
portland_bill has donated!
Re: coolent flush
I think 2 litres will be fine.
It needs to be mixed 50/50 with water. Tap water is ok, distilled or deionised water is better.
Mix it before putting it into the car. That will guarantee the mixture proportions. Putting water and coolant in separately and expecting them to mix is a bit random. It will take time to mix thoroughly, and may give the wrong concentration.
Less coolant reduced its effectiveness at corrosion inhibition, and reduces its anti-freeze properties. Too much actually reduces its effectiveness too.
Get a pot of some sort. Big plastic measuring jug, (Cheap but often don't pour well, so get a funnel too) or similar, or an empty 5l pot, (clean inside) and mix the water and coolant 50/50. Then pour into the car.
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is online now Reply With Quote Quote
Old 29-12-2017   #3
varesecrazy has donated!
Re: coolent flush
Quote Originally Posted by lee hughes View Post
been covered on here many a time..
https://www.fiatforum.com/panda/3551...or-liquid.html
biggest issue is getting the hose off the bottom radiator outlet..
on my 1.1 I CAREFULLY slit the clip off.. , and replaced with a conventional "worm-drive clip"
like a Terry / Jubilee.
it's supposedly possible to remove the "bayonet hose fitting" but on a 10 year old car I would worry about brittle plastic parts failing
Charlie
Cardiff / Oxford
varesecrazy is online now Reply With Quote Quote
Old 29-12-2017   #4
Trader Rating: 1
Re: coolent flush
Quote Originally Posted by varesecrazy View Post
Charlie
The bayonet fitting seems like a good idea, but creates an unnecessary struggle. Probably quick and easy for the production line.
I found the only way to properly grip and squeeze the bayonet release, was from under the car. Then you drown as it comes off. Genius.
As Charlie says, if the 'O' ring seal is damaged, a new hose is the factory answer. Careful measurement of the 'O' ring might be able to source one off the internet, but that creates a big delay.
Old 30-12-2017   #5
Re: coolent flush
thanks guys lee
(T) Coolent keeps going down? Stifler3513 Grande Punto 6 15-11-2013 05:44
(T) Coolent Bleeding? Grim_Evil Grande Punto 5 09-03-2013 17:25
(T) coolent problem!! benjii Panda (Classic) 25 29-04-2011 18:30
(G) What coolent do you use? MadMan0 Punto (Mk1) 3 07-06-2010 16:47
(T) Coolent Silver_Sei Cinquecento / Seicento 2 14-09-2003 04:32
