2007 1.1 Active.
Can any body help me out please?
I only recently purchased the car for my daughter and
I have discovered a gearbox oil leak coming from the plate which surrounds the input area for the near side drive shaft.
I am assuming that this is a failure of the oil seal behind the plate.
As you can see in the attached pictures , it looks as thought somebody has given it a belt at some stage.
And I have also discovered that it is indeed a replacement gearbox.
I am assuming that once I have drained the gearbox and removed the drive shaft and the four retaing bolts to the plate it would be a case of fitting a new seal.
Do you need any specialist tools to remove the failed seal or to refit the the new one?
Any help and advise would be very welcome please
