J Johnnie boy New member Joined Nov 5, 2017 Messages 1 Points 1 Nov 5, 2017 #1 :worship:Hi there can any one help my 55 palate 1.1eco starts ok but revs it head off
koalar Distinguished member Written a review Joined Oct 24, 2016 Messages 9,232 Points 2,098 Location Cheshire Nov 6, 2017 #2 Assuming that when you inspect the throttle butterfly under the air filter housing it is closed shut. Then its likely to be either faulty throttle position can go faulty but rarely exceeds 3000rpm Faulty idle control valve can cause revs in excess of 5000rpm Both of these are in the throttle body Both are easy to test with multiecuscan. Idle control valve can be cycled in the actuator test And a faulty position sensor will read an angle when its shut If its the ICV you can try cleaning it with some carb cleaner. Only really accessible from underneath after removing
M murfman53 Patron member Joined Jun 6, 2008 Messages 324 Points 134 Location ireland Nov 6, 2017 #3 Hi johnnie boy, Here's a link to tps diagnosis and understanding this device. john.
D DaveMcT Distinguished member Written a guide Joined Sep 14, 2009 Messages 19,492 Points 3,294 Nov 6, 2017 #4 Also check the throttle cable is not sticking. Air leaking into the inlet manifold behind the throttle will have the same effect. Has the engine been overheated?
