First you need to work out if its both sides or one.
Cock the wheels one side and put the car in reverse
Release the handbrake and lift the other side rear of the ground.
Spin the wheel as if the car is in reverse then the other way.
Do the same the other side.
If it just one side you will need to remove the drum and inspect
If its both sides its likely to a stuck handbrake. Unless its been sitting for sometime.
I have had this when my Bosch pads became unglued however that's just one possibility.
Its better to diagnose the problem before ordering any parts.
Update
I have checked both sides of the rear wheels and it is only the drivers side wheel that is locking, I have took the wheel off but is as for as i have got, I have had a little look around without taking the drum off at the back and can't find anything out of the ordinary, is it a big job taking drum off and repairing what's inside?
Removing the drum is easy enough........if it's not locked on, which yours seems to be. It could be the shoes seized onto the drum as previously mentioned or perhaps the handbrake 'locking' the shoes in place.
Can you have someone pull the handbrake on and off whilst you observe what happens to the lever as the back of the drum -see if it moves.
Beyond that, changing shoes can be a bit of a pig when you need to tension the springs - specially if you've not done them before.
If you're not confident, a local tyre/exhaust place might be a better bet.
The threaded holes in the drum should be standard 10mm. Wind a couple of bolts in evenly and it should pull off.
A likely problem is that the linings have become detached from the shoes and jamming the drum rotation. Not too common, but reported on here a few times. Mine did this earlier this year. 11 year old shoes, bonding just lets go.
