FIAT Auto Specialist Team
Old 28-10-2017   #1
Israel
High coolant temperature on start
Hello
My 1.2l when turn the key to start motor , it beeps , writes "excess coolant temperature please turn off the engine" ( or close to this ).
It lasts about one second as the engine started , then everything goes to normal .
When it happens , that water temperature gauge jumps to max and red light is on.
As said all this occurs on the moment the engine starts.
Coolant level is a bit higher then 'MAX' like two cm.
On driving every thing is OK , temperature slowly rises from min to middle normal and stays there during the drive.
What's can be the reason for this ?
Thank you
danyra is offline Reply With Quote Quote
Old 28-10-2017   #2
Goudrons has donated!
Re: High coolant temperature on start
I've seen this once or twice before and it's usually voltage/battery related.
The coolant temp sensor works by returning a signal voltage back to the ECU.
Higher voltages returned mean cooler temps.
Lower voltages mean higher temps.
If it can't return a normal voltage signal because it just doesn't have the volts, it can cause this problem.
Before anything else, get your battery checked properly (drop test) and make sure the charging system is working correctly (engine and battery earth leads can rot away)
Likes Sweetsixteen liked this post
Goudrons is offline Reply With Quote Quote
Old 28-10-2017   #3
koalar is online now Reply With Quote Quote
(T) "High coolant temperature" and radio turning on and off fiatritmo Stilo 2 15-06-2015 23:38
(G) High Coolant Temperature ? premcompgw Stilo 14 11-04-2012 11:37
(T) High Temperature Coolant Warning 54 Plate Stilo bronzebabe2005 Stilo 3 17-11-2009 20:18
(T) High temperature light on, coolant gone Happymultipla Multipla 5 14-01-2009 20:50
(T) Radiator coolant temperature too high Ffoxy Grande Punto 11 18-01-2008 12:23
