My Tailgate was intermittent on opening & then just stopped working altogether.
Had to use the key to get into the boot.
Had a look at some of the posts on the forum of which, mostly pointed to micro switch failure.
So got myself from Amazon, some of those cheap body trim removal tools.
So yesterday I removed the tailgate cover (plastic clips & 1 Allen bolt holding the handle).
Now the switch still had its "clickiness" but I still went ahead and removed the whole handle.
Remove plastic cover over barrel lock, unclip barrel lock rod, disconnect electrical connector,
undo 4 x 10mm nuts, & release 2 x clips.
Can't seem to upload pictures, so will add the rest soon as I have worked it out.
