Hello ,
I own a 1.2l 2008 robotic dualogic panda for 7 ears.
Now after a long stand , shift to neutral is problematic.
Mechanic said to wait and when the problem acutes , need to replace clutch and surroundings - about 1000 pounds.
Then i asked what to expect later on . The answer was : at some point , robotic mechanism leaks - about 2000 pounds.
So i have this thought : to convert it to manual ...
Assuming the body , motor and gear are the same , it seems not much work.
Does it makes sense to you ?
Thank you
Thank you
