gerry norris
- Feb 11, 2017
- 58
- 22
Have to replace front right lower suspension arm, It is a straight forward job-couple bolts plus ball joint bolt then release ball joint with ball joint splitter/separator The only thing I notice different is the putting back together you bolt arm back in then jack up arm to a measurement of 187mm between lower edge of arm and upper edge of subframe. have been quoted £167.oo to change arm with the usual years warranty but I notice I can get one made by Magneti Marelli-italy with a 2 year warranty for £34.01 from a firm called Buy car parts. Anybody ever used this particular firm? Anything I should know before I change the arm? IE have I missed anything out?
Many thanks in advance of any replies.
