Boanerges
- Oct 19, 2005
- 71
- 24
A couple of things i noticed today. Driving home in the dark tonight I put on the main beam. Noticed how bright the blue warning light is on the instrument panel, has anyone else noticed? Seems much more prominent than on my previous Punto. Suppose I will get used to it but appears very bright and a bit distracting.
Also, my Dynamic doesn't have a boot light. I had a look and behind the side trim panel there is a small block connector loose with two small female connectors near the hole where the light goes. I reckon this is the feed wire, only issue is before I test it for a supply and earth, does anyone know how it would be controlled by a switch. There is no obvious one on the tailgate.
I fancy fitting a boot light as its a real pain in the dark not being able to see what is in there etc.
Perhaps on the Elegance where it's standard there is a switch fitted on the boot sill or something?
