How does widening the rear track induce understeer in a FWD car exactly?
Using your own logic of making the tyres run on wetter road would cause oversteer, not understeer.
The spring and dampening rates make a far greater difference to compliance, predictability and handling than the track width.
The logic is fine and correct wet and dry are two different things.
In the dry you have reduced the weight transfer on the rear axle by a huge amount
making the difference between the font and rear greater than Fiat intended which is already set for mild understeer
setting up something like a stock Porsche for a particular track track you are adding normally around 8 10 12 or 15mm wheel spacers.
here we are talking 25mm here
on a completely wet road we aren't talking about weight transfer. but again by moving 25mm you increasing the chance of the back overtaking the front.
I was lucky enough to be in the pits for a round of the European cart championship. The weather changed only a couple of minutes before they were due on the track. They had a choice change the rear track or put full wet tyres on but not both. They went for the track and lapped everyone up to 2nd place including those on full wets.
If you don't believe adding 2" to the rear axle affects the handling thats fine by me.
If you don't inform the insurance company that you have modified your car thats fine by me
But because it "feels" better doesn't mean it safe. I not saying its not safe. I would have to be tested by an expert in all conditions. Just by changing the worn out shock for new will make it feel better also
I can understand when axles were hard to come by to fit an alternative thats also fine by me
whether its safe. I don't know. Would I risk it. No.
However now axles are easy to come by and cheap now. I don't see why you would want to preform a major modification and not do it properly
Fiat and Ford changed the front suspension and track to match the wider rear. Take a look at where the front drop links attach to the strut especially at the angle they are completely different
the suspension has to be taken as a complete system. Changing one aspect will have a knock on effect.
