Its the wifes
I have a 2011 vintage panda which has had a hard life
the ABS light is now on
Will a normal code reader get the codes or do i need a one just for fiats and/or ABS
Can you get it to flash lights at you which can be decoded to tell you the fault?
I haven't had the wheels off yet so haven't looked to see if anything is hanging off but it did make a bit of a grindy noise this morning from the back end but i could not see anything out of the ordinary
